How do you create a global preset manager for the workspace?
parityflux
Unread post by parityflux » 30 Oct 2016, 00:30
How do you create a global preset manager for the workspace? I attempted it several times last night with no luck. I tried putting one in a patch, but I could not change the target to workspace. It just kept reverting. I scoured the manual, and the modules wiki, and the forum though I did not find anything that precisely answered this question.
-j
Ariajazz
Unread post by Ariajazz » 30 Oct 2016, 02:57
USINE has a global preset manager called CONDUCTOR. It applies settings for the whole workspace.
parityflux
Unread post by parityflux » 30 Oct 2016, 04:29
I am using HH2. Maybe you are referring to a prior version. I've been through the manual a few times and still can't find the info on how to do it. Also, the term "CONDUCTOR" does not appear anywhere in the text portion of the most recent manual or patching tutorial/guide.
-j
parityflux
Unread post by parityflux » 30 Oct 2016, 04:31
Basically all I want to do is take snapshots of the current state of all items (that are marked with Saved in preset of course) and be able to access the snapshots as presets in a gig. I don't want to load entire workspaces either. That will break the flow. I will keep working at it. I thought this was possible, or maybe it was before in HH1.
-j
parityflux
Unread post by parityflux » 30 Oct 2016, 05:35
I'm going to re-read the manual regarding the Grid. Sorry for the interruption.
-j
iococoi
Unread post by iococoi » 30 Oct 2016, 06:41
hi,
there is an optional workspace preset manager, but by default it's disabled. You just have to turn it on under settings...
http://www.sensomusic.org/wiki3/doku.ph ... :workspace
-io
parityflux
Unread post by parityflux » 30 Oct 2016, 07:42
Iococoi, that's exactly what I was looking for!!!!!!!!!! The hours spent were not wasted though. Thank you so very much,
-j
Users browsing this forum: No registered users and 33 guests
