"Next" grid button doesn't work with OSC
XpiR
Unread post by XpiR » 14 Sep 2016, 18:50
Hi
I'm trying to control the "next" button in the grid with OSC, but it doesn't always react.
The button blue led flashes correctly, meaning that the button receives the OSC message, but I can't jump to the next section.
It only works if I right click on the next button, and then send my OSC message, and then right click again etc... As if the button was in standby mode after each OSC message and needed to be awaken.
And it of course works perfectly with a midi message or with the keyboard (I always used to contro the grid with midi messages)
Unread post by nay-seven » 14 Sep 2016, 21:02
I suppose you have test different OSC mode ( real value/0..1) ?
XpiR
Unread post by XpiR » 14 Sep 2016, 21:07
Yes Nay, I did...
Unread post by nay-seven » 14 Sep 2016, 22:15
ok, so after some test i agree, there 's a strange behavior, waiting for a fix you can use a direct link which work:
Unread post by oli_lab » 14 Sep 2016, 22:42
I may be old school but I still receive all the OSC in devices (one device per osc client) then send busses from the device whose name are the name of the message.
I'm not a fan of this "learn" fonction as usually OSC is pouring and learn a particular message is impossible.
using busses instead make it possible to choose the busses from a list.
as well, using device is easier on the CPU because it is processed on change and not on every cycle.
Unread post by senso » 15 Sep 2016, 12:33
In fact this issue comes from the fact that some OSC apps send only a 1 value, when Usine is waiting for a trigger : 1 followed by 0 value.
Nothing to do in HH2 except the nay-seven tip.
This point will be improved in HH3.
senso++++
XpiR
Unread post by XpiR » 15 Sep 2016, 14:05
OK Nay, it works great with your tip. Thanks!
@OliLab : I don't know if it's "old school", but I also do use the OSCin device, which makes things clearer for me : one project = one OSCin device, really convenient as I use different devices regarding to the stage situation.
@Olivier : HH3? HH3? Oh oh, you should give us more informations!!!!!!!
