Container within a container
if you have a subpatch with lets say a fader and a container. set the fader visible where option to "container" will put the fader in this subpatch container.
now if you go upper level at parent patch level you can make a new container. back to the subpatch, cliquing container of subpatch and seting it's where
option to "parent container" will put this container contening the fader into parent container and so on
mmmm, that's something that I figured out... but it does not work for certain patches I have. Is there any other tool that I can use to have modules and objects in a separate manner but in the same level within a patch?
Can you provide a simple patch where this not work ?
( you still use Usine 5 or ? )
I got it work by inserting sub patches within patches with a container in each one. Yes i'm still using STAGE. I've tried to try Hollyhock several times but no way, you completely rewrote the program and the workflow is different. STAGE does what I need and I got use to it. Honestly I don't want to be in a learning curve again. Thanks for your repply even though I got the solution by myself.
If you can, please precise you use Usine Stage in your posts, cause understand this can be confusing for others users?
Usine Stage is a product made in August 2011...
Users browsing this forum: Google [Bot] and 11 guests
