Hello there,
I'm using the main preset manager (the one inside the workspace) and would like to send the Preset name through OSC.
It's easy for a preset manager inside a patch as I can devices/cables and everything... but I don't know how to have access to this preset manager inside the workspace.
Any idea? Suggestions?
Thanks for the help,
Joe
Get preset name through OSC of the actual preset manager of Workspace
These presets panels can 't be used in this case, but you can change for a preset manager module in a patch, and set his target and where option to workspace ?
Yes, it works perfectly! Thanks!
