Container within a container
Ariajazz
Unread post by Ariajazz » 26 Apr 2016, 00:06
According to Help Files a Container can containt another container:
"The container is like a panel but it can contain several other display modules or other containers"
I've tried any way I can imagine to add a container within another one without success. How do I do that?
Unread post by 23fx23 » 26 Apr 2016, 03:58
if you have a subpatch with lets say a fader and a container. set the fader visible where option to "container" will put the fader in this subpatch container.
now if you go upper level at parent patch level you can make a new container. back to the subpatch, cliquing container of subpatch and seting it's where
option to "parent container" will put this container contening the fader into parent container and so on
Ariajazz
Unread post by Ariajazz » 27 Apr 2016, 04:43
mmmm, that's something that I figured out... but it does not work for certain patches I have. Is there any other tool that I can use to have modules and objects in a separate manner but in the same level within a patch?
Unread post by nay-seven » 28 Apr 2016, 16:39
Can you provide a simple patch where this not work ?
( you still use Usine 5 or ? )
Ariajazz
Unread post by Ariajazz » 18 May 2016, 05:20
I got it work by inserting sub patches within patches with a container in each one. Yes i'm still using STAGE. I've tried to try Hollyhock several times but no way, you completely rewrote the program and the workflow is different. STAGE does what I need and I got use to it. Honestly I don't want to be in a learning curve again. Thanks for your repply even though I got the solution by myself.
Unread post by nay-seven » 18 May 2016, 16:21
If you can, please precise you use Usine Stage in your posts, cause understand this can be confusing for others users?
Usine Stage is a product made in August 2011...:)
Ariajazz
Unread post by Ariajazz » 23 May 2016, 06:19
I usually do it... This time I forgot
Users browsing this forum: No registered users and 78 guests
