reverse on midi sampler
Unread post by rlgsbt » 06 May 2016, 17:47
Is it possible to automate or trigger in real time the "reverse" option for each sound in the new MIDI sampler ? I can edit this option manually in the sound list, but I would like to affect a MIDI learn for all of them in the same sampler.
thanks
Unread post by nay-seven » 06 May 2016, 20:08
Sadly, there no individual or array inlet for this option
don't know if it can suit your needs , but an idea could be to create a new bank and double each sound
then set each second one to reverse mode
save the bank
Now a simple Midi transform module before the sampler with a switch (0 / 1) on the pitch inlet will do the job ?
Unread post by rlgsbt » 07 May 2016, 08:44
thanks Nay-Seven,
A 2d reversed bank is a good idea, but my banks are very large (about 150 sounds) and evole on each new concert. It would be difficult to manage. May be in HH3 ?
Unread post by nay-seven » 07 May 2016, 08:53
Ok, i understand,
so you can maybe add this to the suggestions forum ? :)
