Editing a curve in the grid :
I don't manage to change a curve's shape once I've done my first settings.
For example after building curve A,B,C,D, impossible to edit A again.
Is there a solution?
editing grid's curves
There is a list of (active) curves in the left commands menu.
There you can select the curve you want to edit. (And you can also hide or clear it from there)
If you dont see the commands menu, it is the icon which looks like a list right below the "IB" (Interface Builder) Icon.
I also think you have to select the part on the grid which includes the curves in order to see theese in this menu.
Best,
tL
Best,
tL
Got it!
Of course, once again in Usine, right click and context menu...
Thanks...
Thanks...
