How to get different midi messages from Piano Roll
uge
Unread post by uge » 21 Feb 2016, 16:57
Hello there,
I would like to get chord messages recorded on the piano roll. I'm trying to get them from midi out. The problem is that i don't know how can I get three different messages at the same time.
Any help? :)
Thanks in advance,
uge
Unread post by oli_lab » 21 Feb 2016, 22:57
MIDI is a serial protocol, so a chord is transmitted as (for exemple) 3 notes in a row
if you play a chord on your midi keyboard, the keayboard will send :
noteon ch = 1 note number = 65 velocity = 100
noteon ch = 1 note number = 68 velocity = 100
noteon ch = 1 note number = 72 velocity = 100
it will be very fast but still should be recorded on the piano roll
uge
Unread post by uge » 22 Feb 2016, 21:16
Thanks for your reply Oli_lab. The thing i'm trying to do is get these three messages individually, using the midi out of the piano roll.
I've tried the Unpack patch. But it was hard to me get the three messages.
Any idea?
uge
Unread post by nay-seven » 22 Feb 2016, 22:40
try the script named Midi expanded voices and choose from first in the out order parameter
uge
Unread post by uge » 24 Feb 2016, 18:36
Thanks Nay-seven :)
It works like a charm!
Users browsing this forum: No registered users and 41 guests
