triggering next sample in a list
Andrulianblog
Unread post by Andrulianblog » 15 Feb 2016, 21:57
I really love using Hollyhock II, it's opened up loads of creativity possibilities through the granulators, groove engines and automation. I've recorded numerous tracks in a range of different styles. I've also started looking into the massive potential provided by patching options.
So I'd like to try and use HH2 to create a mixtape or DJ set. Whilst I can control a lot of the samples and effects live, I'd like to be able to set up a list of bass samples in a normal sampler and then trigger them in sequence I've read the manuals and the wiki and can't seem to figure the easiest way to do this.
I think either a counter, local synchro or array could work but what would be the most efficient way to do this?
Many thanks,
Andy
r.erorr
Unread post by r.erorr » 16 Feb 2016, 10:50
In browser: Modules -> Data -> Lines,Steps,Switches,Curves. Just connect them to play button of sampler! :)
Andrulianblog
Unread post by Andrulianblog » 16 Feb 2016, 23:01
Many thanks for your reply.
The sequenced buttons seem to work better than the sequenced steps. The samples are quite long so I just need to figure out the correct synchro and timing settings otherwise it triggers the next sample too soon.
Many thanks,
Andy
Andrulianblog
Unread post by Andrulianblog » 17 Feb 2016, 23:31
I've been thinking there must be an easy way to do this - and there is. It's simply a case of connecting 're-starting' to 'next' on the sampler. This will also allow you to use flow control and switches if required.
The wiki says re-starting Works properly only in Loop mode synchro. but I've not found any problems so far.
Andy
Unread post by nay-seven » 18 Feb 2016, 08:56
well done Andy
Users browsing this forum: No registered users and 46 guests
