I'm looking for the way to create a sustain effect.
This with a button or with a pedal : I have now an adatator Midi expression (audiofront) and a pedal effect.
So I searched in the midi modules, tried to patch but I didn't find.
If you have an idea of how to proceed, thank you !
Gwen
Sustain
sephult
What kind of sustain effect you looking for?
Can you elaborate?
I did once create a sustain pedal patch that was voice dependent. I am looking back at it.
I had it under the add-ons but had some issues with it, among issues with my pedal not being debounced. So I retracted.
I can help if I knew more about what you were looking at doing. (Might help me remember what I did...lol)
-s
Can you elaborate?
-s
Hello Sephult,
Thx to reply.
I'd like play a sample, take a small part, and extend this frequency, as a sustain effect could do it.
(Because I thought use a virtual effect)
For the moment, I have a volum&expression pedal connected to Usine thru an adatator Midi expression (audiofront).
And I don't how create a good patch.
I hope this Is more precise for you.
Thx
G.
Thx to reply.
Thx
G.
