vst don't show up... again
XpiR
Unread post by XpiR » 10 Nov 2015, 12:55
Hi
For an installation I just installed HH last version on an old PC Win7 32bits.
My patch works perfectly, but I don't manage to see my VST plugs.
I run the usual procedure: choose my vst folder, scan for vst in the setup pannel
Once scanned, they just don't show up in the plugins browser, which remains empty...
I tried to download new VSTs, which are for sure compatible with my 32bits system, but same thing.
Any idea ?
drakh
Unread post by drakh » 10 Nov 2015, 17:09
do the VST show up in other 32bit DAW ? (try to download tracktion 4 32 bit and test it)
XpiR
Unread post by XpiR » 12 Nov 2015, 15:01
I did try in Tracktion - didn't know this soft -, 32bit version, the VST do show up...
They show up in Reaper 32bits too.
Unread post by nay-seven » 13 Nov 2015, 09:58
Usine 32 bits needs 32 bits plug ins, there 's no bridge like in Reaper.
Are you sure you have installed the 32 bits version of these plug ins ?
XpiR
Unread post by XpiR » 13 Nov 2015, 17:45
Yes Nay, I know that and I loaded 32bit VSTs like Voxengo Sound Delay for example...
Nothing...
Unread post by nay-seven » 13 Nov 2015, 18:17
Can you open the usine/config/plug ins folder ?
you'll find several .init files you can open with a simple text editor
check your vst appears in the Knownplugins.init file , you can also check what you see in the others init files
Users browsing this forum: Google [Bot] and 28 guests
