DISPATCH AUDIO BY GRID SECTION PASSAGE
Shintylla
Unread post by Shintylla » 23 Oct 2015, 22:02
Hi guys,
the title say it all. How can I dispatch audio from 1 out to the 2nd when the cursor passes the end of grid section? no matter if the sequence is looped or passed to the next.
Thx
Shintylla
Unread post by Shintylla » 24 Oct 2015, 17:38
I put a toggle to switch the dispatcher through a button. But what is the impulse or data that the grid emits when the cursor reach the end of a section?
Unread post by nay-seven » 24 Oct 2015, 18:01
Generally, the best way is to provide an example patch or workspace to ask for help,
cause in Usine as you know now, there's always several ways to do things
here a workspace example of a way to trigger a dispatcher with the grid envelop
Download
Shintylla
Unread post by Shintylla » 24 Oct 2015, 22:01
Thanks Nay,
I upload my patch. I didn't understand how your patch works. I saw on off-caption value dispatch1 but what is it?
http://www.sensomusic.com/forums/upload ... 201.01.wkp
Shintylla
Unread post by Shintylla » 24 Oct 2015, 22:12
Ok I got it, you automated the switch with a curve. But it doesn't work if the section is looped doesn't it?
thx
Unread post by nay-seven » 24 Oct 2015, 22:22
you ask for a change "when the cursor passes the end of grid section"
so in the workspace i've uploaded, if you pass from section 1 to section 2 the dispatch value change if this is done automatically (with a blue arrow) or manually (with the next button) ?
in the wkp you upload, there's no dispatch and the rack is not in the grid so...??
Shintylla
Unread post by Shintylla » 25 Oct 2015, 08:57
Yes Nay,I just wanted to show you my method if the clock module was right to do so, but it doesn't, t syncs with master tempo not with the grid. However how can I make my patch "detect" when the cursor reaches the end of a grid section? even if it is being looped..Your method is an automation, won't work with looping.
And also, is there a way to change pass to next-loop-repeat x1/x2 value on the top of the grid with a midi command?
Thx
Unread post by nay-seven » 25 Oct 2015, 10:12
In modules/interface controls/usine panels/ you have 2 modules you can check
Grid section settings
and
Grid settings
Shintylla
Unread post by Shintylla » 25 Oct 2015, 12:09
Thx Nay,
sorry for such a simple question for you, I'm still a beginner
Users browsing this forum: No registered users and 60 guests
