Multipair cable
XpiR
Unread post by XpiR » 12 Aug 2015, 16:33
I start to work with a quadriphonic system, and heading for octo.
I often face this situation :
Can't imagine with 8 or 16!
Is there any simple solution to wire only one "multipair" cable with
out1->in1
out2->in2
...and so on.
Unread post by 23fx23 » 12 Aug 2015, 17:42
if you this often IML can be cool for that you can send only one message to wire all the stuff one shot via the send usine internal message module
using CREATE_LINK command
http://www.sensomusic.org/wiki3/doku.ph ... es&s[]=iml
XpiR
Unread post by XpiR » 12 Aug 2015, 17:54
Thanks for answering, so that's a new field to me...
I have to check this out!
drakh
Unread post by drakh » 13 Aug 2015, 13:43
ctrl+shift when wiring is not working ?
XpiR
Unread post by XpiR » 13 Aug 2015, 13:59
Well, I didn't know this key combination, but it doesn't seem to have any effect when I wire...
