Normalize
CleverConQueso
Unread post by CleverConQueso » 03 Aug 2015, 22:53
Anyone got a trick to normalize a file on the fly beyond playing it through once and capturing the loudest volume?
Unread post by 23fx23 » 04 Aug 2015, 00:58
not perfect but maybe could use wavform display with a (abs) + max_array module to get the approximative peak (as its a low rez proxy, but think it would be ok in most cases) on the fly, otherwise i think this can only be done with sdk or script (if binary load/read has been implemented in scripts, not sure if yet) then scanning raw data via a loop to get peak and adjust compensating level according to this.
something like this
(tho think maybe should subtract a little margin out of 1/x to prevent eventual clipping if ever there were higher sample values in files not catched by the wavform array)
Unread post by senso » 04 Aug 2015, 10:15
well done FX23
CleverConQueso
Unread post by CleverConQueso » 06 Aug 2015, 00:55
TIL: There's a normalize button on the sample player. Just had to look for it harder.
Still, I like the super slick solution proposed above.
CCQ
Unread post by 23fx23 » 06 Aug 2015, 02:17
that's what i said myself i thought i had seen it before, also went too quick and missed it^^
