Joystik
Unread post by cmodica » 26 Nov 2007, 19:19
I want to use a very cheap joystik to control usine. But i have 2 problems.
1 - It is impossible to use more than one Joystick module. If i put a second joystick Module on an other track it doesn't work and i have the message "Error : Enebled to open Joystick" ?
So i can use "send Bus" and "get bus" but ...
2 - On my very cheap Joystick i have more than 4 buttons and two 360° controller wich can control four axes. How can i use all of them ?
And a last question : Is it possible to receive Midi CC from my Joystik in usine ?
Unread post by senso » 26 Nov 2007, 20:04
Yes you can have only one joystick module in Usine.
It seems strange but I'm not a joystick expert and actually, I don't know how to access to the 330° controllers with window. (I use a too basic library)
Be patient, the improvement is in my 'do-do' list.
You can transform joysticks value to CC with the 'create Midi msg' module.
Unread post by cmodica » 28 Nov 2007, 18:31
Ok thank you Olivier, i will be patient !
But i find this donationware plugin (http://pagesperso-orange.fr/silicon_silicium/index.html)
and it is a good way to use all my joystik buttons. I need a little bit programation with Midi Filter and Logical Math Module but it works fine.
Good evening.
Unread post by senso » 28 Nov 2007, 20:01
Perfect solution!
