VST randomizer
hegeldas
Unread post by hegeldas » 21 May 2015, 22:51
I am an old usine user, just upgrade to hollyhock and i am a little bit confused, have i miss something or the helpfull VST randomizer of usine isn't exist in hollyhock, is there an addon or something to do the same than in usine???
Unread post by 23fx23 » 21 May 2015, 23:32
you can for exemple link 'params out' array pin of vst to an 'array display or set', a pass if change connected out of this array back to params in and press randomize on the array
hegeldas
Unread post by hegeldas » 23 May 2015, 01:07
Ok, so, that is confirmed, no direct script to do what vst randomier did in usine... I have to learn :)
Users browsing this forum: No registered users and 50 guests
