Preset manager triggers button by magical forces
parityflux
Unread post by parityflux » 19 Apr 2015, 03:54
Whenever I click on a preset, it triggers the circled button. I actually don't want that to happen. Any clues? It happens on my other patches as well that are similarly configured.
-john
Unread post by 23fx23 » 19 Apr 2015, 04:29
Did you disabled "save in preset" on it's options?, alternatively, delete it and recreate one with the option disabled
parityflux
Unread post by parityflux » 19 Apr 2015, 05:59
Wow. OK. Well I'm starting to get how that works. This is one of those very frustrating HH things. So it's my "MIDI Switch" that needs to have "saved in preset" selected. I can make that work, but the pre-condition is that the container patch has to have "saved in preset" (SIP) selected.
It's this sort of non-uniform hierarchy that makes things frustrating:
- Other items in the container (same level) must have SIP selected or not in order for their state to be saved in preset (easy to understand)
- The patch has to have SIP selected for the preset manager to work (at all); not so sure I get the reasoning, as I presume this would mean the parent (Rack) level's preset, which shouldn't concern itself with grandchild properties.
-The preset manager has it's own SIP. What would that be for?
I code for a living and I am either too hard-headed to get this, or it's simply ... non-uniform.
-j
parityflux
Unread post by parityflux » 19 Apr 2015, 06:09
I'm pleased that I didn't have to recreate the preset manager. Just unselecting SIP on the button worked. I'm starting to use the built-in presets introduced in HH2, and I believe "recreating" those would not be possible at all anyway. There's no way to find them, much less delete them.
