reverse value?
r.erorr
Unread post by r.erorr » 17 Apr 2015, 00:39
how can I convert increasing value to decreasing value? Sounds simple, but value mapper doesn't work in that way. This is very useful especially for inverse XY controls, thought I never managed to solve it
martignasse
Unread post by martignasse » 17 Apr 2015, 01:40
if your value is between 0 ->1, use the math module 1 - X
you get the idea, adapt for the range you use
or i completely misunderstood your question
Unread post by rlgsbt » 17 Apr 2015, 08:37
you can also use the module "change scale" and invert values between in and out values.
for example change the scale from 0 to 1 in 24 to -24 (the module will invert and change the scale)
r.erorr
Unread post by r.erorr » 17 Apr 2015, 12:00
ah, yes "between 0 ->1" is solution. I tried with different values - that's why it didn't work.
