reverse value?
martignasse
if your value is between 0 ->1, use the math module 1 - X
you get the idea, adapt for the range you use
or i completely misunderstood your question
you can also use the module "change scale" and invert values between in and out values.
for example change the scale from 0 to 1 in 24 to -24 (the module will invert and change the scale)
ah, yes "between 0 ->1" is solution. I tried with different values - that's why it didn't work.
