simply control my hardware synth ?
julien_
Unread post by julien_ » 20 Mar 2015, 13:36
hi,
i am back to usine after a first try some years ago...
i ve spent my morning to try to control my microbrute synth with usine.
I thought it would be easy but not at all and i am confused...
it seems my microbrute desperately waits for a note off message...
because is it monophonic, it plays the first note reveived from usine and after nothing
why midi module are not build with an option for midi note off before a new note on is played ?
i ve only found this on the piano roll.
i want to play sequences of memorized note.
do i have to create a patch that i connected to step midi module that would note off all the note on that have been played ?
like
step midi module : C3 note on
> C3 note off
step midi module : D4 note on
> D4 note off
step midi module : E3 note on
> E3 note off
but maybe there is something simpler ?
thanks for your feedback
j.
drakh
Unread post by drakh » 20 Mar 2015, 14:30
midi transform module is the easiest way to solve this. just patch to output of midi module that creates just note on messages, and setup the length of the note, and midi tranform module creates note off messages for you.
