linear to log/exp function for Hz
Unread post by 23fx23 » 14 Mar 2015, 15:47
this should be pretty simple maths and i feel ashamed to not be able to solve this.:rolleyes:
anyone knows what is the math or script code to convert a 'linear' input value to a exponential or log one, and what is the best to use for Hz .frequencies?
you know like equalizers have a typical log representation. tried log and exp but not sure the way to do..
I dlike kind of the same thing as the mapper curve module effect, with a 0-1 range 'linear' array on input that would output a frequency response according to min/max freq.,
or output a 0-1 range that i multiply by max freq.
or exactly the curve when you got a 0-1 fader swiched to log scale .
plz help!
Clearscreen
Unread post by Clearscreen » 16 Mar 2015, 03:09
I'm interested in this at the moment as well - anybody got any suggestions?
Unread post by senso » 16 Mar 2015, 08:06
use the module power.
try various B coeff for example 5 or 1/5 depending of the scale conversion
with B = 5 we have
Freq(Hz) = 20000*power(ValueLinear,5)
ValueLinear = power(Freq(Hz)/20000,1/5)
choose the B coeff as you want ie 3,4,5,6
senso++
Fléau
Unread post by Fléau » 16 Mar 2015, 11:41
For equalization purpose,
if we consider that 640Hz is the half value,
5 is the right coeff.
Unread post by 23fx23 » 16 Mar 2015, 21:19
thanks a lot for the help olivier!!!!
