Filtering out crossbleed
Golcondio
Unread post by Golcondio » 12 Nov 2007, 10:43
Can someone help me out?
My instrument has two sets of strings, one tuned like a bass, one tuned like a guitar.
Each set of strings has separate output circuitry.
I set Usine up so that each channel is processed by a separate stereo track.
Unfortunately, when I play the strings towards the middle of thefretboard the sound leaks into the other channel... I thought that, since it's the lowest string on the bass side and the highest on the guitar side, it should be possible to gate the frequencies of the offending strings; I got some results but inevitably deadened the sound (especially the guitar part).
Is there another way to achieve the same result, but without the inconvenience?
Toshiba m40-281, Motu Ultralite, dbx166A compressor, Vassilevsky tap-guitar, M-Audio Oxygen8v2, Usine
