What does it mean when the array "In" flashes?
ahonoe
Unread post by ahonoe » 11 Oct 2014, 16:49
When I click on the an array module I see the "In" flash from a red "array[-1]" to a white "array[48]" (the length of my array). Can anyone tell me what this flashing means?
Regards,
Scott
Unread post by nay-seven » 13 Oct 2014, 21:33
depending of what you linked to this array input , but must be the refresh value
ahonoe
Unread post by ahonoe » 13 Oct 2014, 21:35
I linked the output of an array without sliders to one that has sliders so that I can monitor the values in the first array. The input on the second array flashes red every once in a while, even whe the values in the first array are not changing.
Regards,
Scott
Unread post by nay-seven » 13 Oct 2014, 21:39
i will investigate, but don't worry , i think the module simply verifies , time to time, if nothing has changed :-)
ahonoe
Unread post by ahonoe » 13 Oct 2014, 21:40
Thanks Nay.
Regards,
Scott
Users browsing this forum: No registered users and 100 guests
