Viral Chaos Patch
runagate
Unread post by runagate » 28 Oct 2007, 01:24
Plugging away at making live Usine projects for my new band I've learned a lot but not enough to know if this idea is feasible:
I am wondering if there's a patch that could be made which would automatically send out cables to the VST that it's hooked up to, one for each automatable parameter, and introduce midi CC jitter/chaos, small parameter changes, into the automation of the plug-in. I've read about module development but can't understand it well enough to know if that sort of automatic cabling is possible.
- runagate
Unread post by senso » 28 Oct 2007, 20:29
there is no way to create jitter automatically on VST's.
The best way is to use the data/random generator and set the min/max values between the range you want.
runagate
Unread post by runagate » 29 Oct 2007, 01:48
I definitely have tools to do this, I was more curious about "automated cabling" something along the lines of "set connection to all parameters" option for speed-of-use live.
Modismaster VST is my favorite midi CC# chaos jittery plug-in.
Unread post by senso » 30 Oct 2007, 18:31
Such 'automated cabling' can be very hard to implement.
For examples some VST have more than 500 params and some of them can't support jitter effect (like switches). So how to decide which param is a good candidate for jitter?
