CREATE_LINK confusing behavior... A couple of questions!
All -
I'm learning IML... Sorta...
If I create a module from a subpatch, e.g.:
CREATE_MODULE xyz 6 100 100 mypatch.pat
it works great, though the module's caption says it is "mypatch"
Any attempt to use xyz, e.g.,
CREATE_LINK xyz OUT somethingelse IN
and I get a "Var Not Found XYZ"
Question 1: Should I be able to use xyz as a modulename in CREATE_LINK?
Question 2: Where is the module name visible? Everywhere I look I cannot see xyz, I see "MYPATCH" - the subpatch's filename?
If I use the #s, e.g.,
CREATE_LINK 17 2 13 0
everything works great....
Curious, but if I use a:
CREATE_LINK 17 OUT 13 IN (using the terminal's names, not indexes)
everything works great, however, it ALSO tells me
Var Not Found OUT
Var Not Found IN
even though it worked.
Probably noob questions...
Shawn
4/30/15 edit: This was a bug & it was fixed in HH2.
Var Not Found OUT
Var Not Found IN
Shawn
as said in the IML page
The module type is set by the parameter id , then the module is renamed with the modulename.
so
CREATE_MODULE vol 4 100 100 // creates an audio volume module ( because of it's ID 4) , then rename this module vol
so
CREATE_MODULE xyz 4 100 100 // creates an audio volume module and will rename it xyz
so
so
Understood.
Feels like it's not working for subpatches. Still no luck.
I can't tell if this is a bug affecting subpatches, or if I'm just missing something.
The following demonstrates the issues with CREATE_LINK with subpatches.
I have similar issues elsewhere using IML with subpatches.
Shawn
The following code works great:
CREATE_MODULE GEORGE 4 200 200
CREATE_MODULE SUSAN 4 400 200
CREATE_LINK GEORGE 'OUT 1' SUSAN 'IN 1'
And reports the following in the console (the 'Var not found' messages are erroneous, because the link was formed correctly):
process msg CREATE_MODULE GEORGE 4 200 200
Create module TpgVolume_audio 261
SET_VAR String LAST_CREATED_MODULE_NAME = GEORGE
process msg CREATE_MODULE SUSAN 4 400 200
SET_VAR String LAST_CREATED_MODULE_NAME = SUSAN
process msg CREATE_LINK GEORGE OUT 1 SUSAN IN 1
Var not found GEORGE
Var not found OUT 1
Var not found SUSAN
Var not found IN 1
But this does not (IN & OUT are terminals & LIFEPATCH.pat is a subpatch that works fine):
CREATE_MODULE GEORGE 6 200 200 lifepatch.pat
CREATE_MODULE SUSAN 6 400 200 lifepatch.pat
CREATE_LINK GEORGE OUT SUSAN IN
This is reported in the console:
process msg CREATE_MODULE GEORGE 6 200 200 LIFEPATCH.PAT
Create module TPgInput_DATA 20
Create module TPgOutput_Data 21
Create module TpgShape 334
Create module TpgPass_Event 157
Create module TpgEqual 49
Create module TpgOr 51
Create module TpgPlus1 291
Create module TpgSelector_Color 342
Create module TpgColor_Chooser 223
Create module TpgSub_Patch 6
process msg CREATE_MODULE SUSAN 6 400 200 LIFEPATCH.PAT
process msg CREATE_LINK GEORGE OUT SUSAN IN
Can't create/delete link GEORGE OUT SUSAN IN
Shawn
Var not found OUT 1
Var not found SUSAN
Var not found IN 1
Never got this to work. (CREATE_LINK between subpatches.)
The beauty of HH, though, is that there a many ways to do what you wanna do...
I found a way to automate using the #s, e.g.,
After numerous attempts, I couldn't get IML to talk to modules within a subpatch. Sure looks like it should do that (I think this is another symptom of the same problem...). Rather than pull my hair out, I just created data inputs, negating the need to communicate directly to a module within the subpatch.
There's always an alternative approach to get the job done. I *really* love that about HH.
Followup...
This now works in HH2.
Still get the erroneous 'Var not found' messages though. But the links are properly created in subpatches now.
Nb you sometimes have to manually rename an item to access it via iml. This via clicking with alt or ctrl i dont remember on a module header.on top of the actal name.
Thanks, good to know.
Hard to do in the middle of a script, though.
yup but i mean man should rename it only once at start Befor anything is done. before iml access it. Like "myfader" at a header name, not just item caption. and this should be then the "id adress" used within the scrip Or sendiml module.
Oh sorry i just get what ya mean by in middle of a script mm
Users browsing this forum: Google [Bot] and 26 guests
