Usine and "Capteurs"
Unread post by cmodica » 25 Oct 2007, 11:08
is it possible to use "capteurs", like Interface-Z materials with Usine ?
http://www.interface-z.com/
Did Someone try it ?
Unread post by bsork » 25 Oct 2007, 13:32
Hello cmodica, I can't say anything about interface-z specificially, but if a devide is capable of generating and sending MIDI, OSC, audio or some data that can be interpreted as coming from a qwerty keyboard, mouse or joystick - it can be used together with Usine in one way or another. as long as your computer has the setup to receive those data, of course.
Whether a device is practical or not, is an altogether different matter...
Unread post by cmodica » 26 Oct 2007, 10:28
Yes that's what i think too ....
Unread post by senso » 27 Oct 2007, 10:47
Also, you can use the 'Kitchen pack' add on, a set aof ready made patches designed to handle data's from such devices.
Also, Usine works fine with Open Sound Control protocol.
Unread post by cmodica » 27 Oct 2007, 15:01
Thank you,
i will test it soon and i will tell you on this forum.
