OSC send format and touchosc
La Tenaille
Unread post by La Tenaille » 18 Oct 2013, 13:07
I'd like to send data to feedback a multi-toggle touchosc module.
My trouble is the names sent :
For touchosc it's
/1/name/1/1
/1/name/1/2
/1/name/1/3
and Usine sends
/1/name/1/1-01
/1/name/1/1-02
/1/name/1/1-03
In touchOSC editor I can't find a way to rename the multitoggle module correctly, so is there a workaround, or do I have to create a single data OSC send per multi-toggle cell (about 50 modules in my case) ?
ahonoe
Unread post by ahonoe » 02 Aug 2014, 15:45
Interesting. I have exactly the same problem. la tenaille, did you find a solution to this?
Regards,
Scott
La Tenaille
Unread post by La Tenaille » 03 Aug 2014, 19:12
Hi Scott,
No I haven't, and I've left multi-toggles because its feedback is not reliable. It seems to be a known issue, and not fixed yet...
ahonoe
Unread post by ahonoe » 05 Aug 2014, 15:25
Thanks. I kinda found the same thing so I've switched to Lemur.
Good luck!
Regards,
Scott
Users browsing this forum: Google [Bot] and 9 guests
