Binds auto calibrate and reset calibrate?
gurulogic
Unread post by gurulogic » 29 Jun 2014, 21:18
What do these options do? Cannot find in the manual.
Thanks!
Unread post by nay-seven » 30 Jun 2014, 12:35
By default the bind calibrate your bus source and your target .
-The auto calibrate option will adapt the bind, for example, if you change the mini/maxi value of your bus source.
-the reset can be necessary in some cases, when you change values , inactivate the auto calibrate...
