Patch Locked?
Jules.W
Unread post by Jules.W » 17 May 2014, 22:40
I try to find the solution by myself and I've made some researches on forum but in vain...
I have an issue, and I don't know if there is a bug or not...
It's very simple.
I would like to modify a little the PadKontrol.
I just want to add Random on Start position parameters for all players.
When I'm in the Sub-patch, I can switch between the 16 players.
I can easely put a Random on the first player but it's imposible to move and add anything on the rest...
It's also impossible to use a Buss Data...
There is a Lock Fonction anywhere?
Thanks a lot!
joffo78
Unread post by joffo78 » 17 May 2014, 23:02
hello. I think is because the pad kontrol is a polyphonic patch. It means that all the modifications made on the first voice of your patch
can be applied clicking on apply polyphony.
Jules.W
Unread post by Jules.W » 22 May 2014, 15:12
Exact!
Thanks Joffo.
