Filtering out lowest midi note
awinterstale33
- New member
Here an example for a chord or short sequences , the synchro will determine the calculation frequency
Download
Download
awinterstale33
- New member
Alright cool thank you. I will check it out as soon as I get home! Basically I want to send the bass note of a chord to a different instrument in kontakt.
awinterstale33
- New member
It works! Thank you very mush. Now what I don't understand is why I cant put two vst's in the same patch. Or why that pop up window doesn't appear anymore when you drag and drop something?
edit: I figured out why the drag n drop and menu wasn't working. When I have Usine on my extended desktop, those things don't pop up but when I try it with extended desktop disabled, it works fine. A bug possibly? I'm using Usine 32-bit on Windows 8.1 64-bit
for the 2 monitors, can you please create a bug report..?
I will test soon, but its always better for us to maintain the bugs list to fix
