Am a bit stuck trying to toggle between 2 sets of a data for an input.
I would like to use a switch which either:
* sends a specific value (constant) to a knob when the switch changes from 0 => 1
* allows the knob to act as normal when the switch changes from 1 => 0
In the uploaded patch, it always seems to be sending the constant value. So I guess I'm trying to write an "if" statement, but not really sure how to achieve it.
Niggles
Toggle input data values
Digital Director & Programmer by Day | Musician By Night
iMac Core I7 | Usine | Logic | Leap Motion (loving it)
http://www.tribe404.com
maybe i misunderstood, but to resume
if switch On the knob is the master, if OFF a constant is used..?
so here a way:
Download
so here a way:
Download
I tried your patch but clicking the knob doesn't seem to send a new value - the wet fader stays the same.
yes, but the formant wet value is updated
now, if you want the knob be updated too, you have to link it this way
Download
Download
Excellent - thanks!
I will use this for other times I need write:
if(foo == bar){
// do something
} else {
// do something else
Sorry if this was a basic question, but I tried many things - some of these "logic" loops are not so obvious in Usine - but once an example has been given it should be easy.
if(foo == bar){
// do something
} else {
Users browsing this forum: Bing [Bot] and 133 guests
