Receive time clock from device : Usine rounds the value
La Tenaille
Unread post by La Tenaille » 28 Jan 2014, 12:45
If usine receives time clock tempo 120.3, it oscillates between 120 and 121. Is there a way to have a better precision ?
ceasless
Unread post by ceasless » 28 Jan 2014, 16:30
I don't understand why Usine (or anyone/anything) supports floating point tempo. Do you have a device that supports it? Because I've only seen it in Usine (though I'm not the most experienced) and I just can't wrap my head around why it is so tricky to just have a nice round BPM.
La Tenaille
Unread post by La Tenaille » 28 Jan 2014, 17:22
Hi ceasless,
Precise tempo is usefull for live looping ;)
tom6
Unread post by tom6 » 28 Jan 2014, 18:39
hi!
did you try to disable the perfect sincro option ?
Tom
La Tenaille
Unread post by La Tenaille » 28 Jan 2014, 19:48
You're right, perfect synchro was disabled.
Thanks tom6
ceasless
Unread post by ceasless » 30 Jan 2014, 01:58
Okay I'm seeing decimal tempos everywhere now. I only really noticed them in Usine because it will often read 88.97 when I set it to 89. Do I understand correctly that it becomes particularly useful for tapped tempos?
La Tenaille
Unread post by La Tenaille » 30 Jan 2014, 11:15
Tap tempi or "handmade" loops... because human isn't rounded :D
MoonSafari
Unread post by MoonSafari » 29 Mar 2014, 16:28
I had to build my own tempo sync to be able to sequence Usine from an external device (elektron octatrack) , because Usine was not acurate enought.
La Tenaille
Unread post by La Tenaille » 29 Mar 2014, 22:48
Usine is still not perfectly synchronized with mobius (close, but not perfect).
I've found (today!) my solution : a script in Mobius vst that sends a midi message each time the loop restarts. In Usine, I use this midi note to trigger the cycle.
seamus
Unread post by seamus » 31 Mar 2014, 21:55
That möbius script sounds like a cool solution!
Users browsing this forum: No registered users and 27 guests
