Poly-Rythm sequencer enigma
noise2sine
Unread post by noise2sine » 23 Jan 2014, 15:10
I have made a simple a version of a patch named "Polyrythm sequencer". In my version there is no more sampler or Fx. The patch is only for midi.This tool is really great.But i have a regular bug at some point.When you press the edit button, you have access to the different steps where you can choose how to tune each step.You can can to -12 to 12 . At some point while using the conductor or whatever, there is bug and the only value i can choose are -12 or 12 :( Then it's impossible to choose another value .
Where can i rewrite those values ?
http://www.sensomusic.com/forums/upload ... uencer.wkp
Thank you
Unread post by nay-seven » 23 Jan 2014, 16:16
it's a Usine 5 workspace right..?
when i open it's look strange and with many faders ( named faders) and nothing seems to work..?
noise2sine
Unread post by noise2sine » 23 Jan 2014, 16:20
Yes it's Usine 5
Nothing is working ?
noise2sine
Unread post by noise2sine » 23 Jan 2014, 16:37
As i have uploaded the the bugged version, it's seems that the patch is broken.
Here's the new link :
http://www.sensomusic.com/forums/upload ... st%202.wkp
The values of the steps should work in this patch, my question is where can fix something if it's blocked again ?
Nay
thank you
Unread post by nay-seven » 23 Jan 2014, 17:19
ok, so it's seems that the mouse mode of this matrix change for x reason, so it sometimes it's jump from fade to toggle..
add a constant module of 1 to the mouse mode inlet, will solve the problem ?
noise2sine
Unread post by noise2sine » 23 Jan 2014, 19:04
Thank you Nay ! it's working perfectly
noise2sine
Unread post by noise2sine » 06 Feb 2014, 10:44
I'm facing the same problem with the other step sequencer in the patch, i can't find the other matrix corresponding to the others sequencer in the patch.Even with right click and "find in patch" nothing happen contrary to the first sequencer. I think it's because of polyphony.
How can i solve that ?
Thank you
Unread post by nay-seven » 06 Feb 2014, 10:59
you can click on each polyphony number of your patch to open it
here an example for an other question:
noise2sine
Unread post by noise2sine » 06 Feb 2014, 11:03
Even with the version 5 ?
Unread post by nay-seven » 06 Feb 2014, 11:09
yes, you have an equivalent like this:
Users browsing this forum: No registered users and 150 guests
