Euclidean Rythms
noise2sine
I'm working actually in something almost similar, i don't have found yet the fill part, but I've add other possibilities, named "IRS" like Inverse, Roll and Swap , and center balls changes the notes pitch ( manually or by physics engine)
tomorrow, i think..
for the moment you can try my patch http://www.sensomusic.com/forums/upload ... umbers.pat
Cool, thanks to share Joffo
noise2sine
Thanks Joffo, For which version of Usine is it for ?
I suppose it was first for 5.80, but works in hollyhock,
Just resize some objects and drag and drop sounds on the wave display panels
noise2sine
it's a very cool patch ! i'm still using the Usine 5.80. I was wondering how i can change the note knob with a knob with midi note names (c1,c#1) would be more practical for me because i'm using it with battery.
thanks
thanks
you can use a listbox module , you have to write the list yourself , then link the outlet text to the inlet caption of the knob this way:
Add-On uploaded ( Seslatero)
