I was using the grid to select presets and engage and bypass a delay.
It is handy to be able to select a preset and then have the delay either bypassed or active depending on the grid patch but I would like to be able to also with a midi controller bypass the delay so that I can freely toggle it. At the moment when an item is controlled by the grid I am not able to control the switch or even change it. Adding a pass if change module somehow? Is that the secret?
Pass if changed for grid items
Very often it is the secret, yes!
"Pass if changed" doesn't lock up the inlet it's connected to; it operates as if you connected something to an inlet, which gets the current value, and then disconnect,
I use pass if changed all the time! it is a miracle module.
Pass if changed doesn't help when the grid has taken over though
How can I enjoy this style of control with an item controlled by the grid?
I suppose the solution is to not use the grid for the bypass of a vst and to leave that to my midi controller
Users browsing this forum: No registered users and 136 guests
