Is this the best way to route the midi to my synths?
I use a midi matrix and send to different buses for each synth.
so far it works well but one problem I have is when using the grid i cannot select the paths. There is no way to access the matrix buttons for automation or selection in the grid. So perhaps it is better to use presets with the matrix for the different routings?
http://www.sensomusic.com/forums/upload ... matrix.JPG
http://www.sensomusic.com/forums/upload ... output.JPG
best way to route midi to synths?
the matrix is an advanced array, so you can use the store array script for this, this way you can automate the fader current num
i forget:; to have a good automation, add an has changed module between the fader and the get button...
Users browsing this forum: Bing [Bot] and 131 guests
