hollyhock physics example to midi
hi - i have probably missed something already there, but I would like to output midi notes from the Hollyhock physics engine example, rather than trigger samples as is the case now. Is there a tute that covers something like that, or an older add-on that I could deconstruct to give me some tips
thanks, greg
thanks, greg
here an example, up is the current patch , down the midi version with a Plug-in, of course you can use buses if you want have your plug-in in an other rack.
*You can add faders to min and max inlets of the last change scale to set midi note range.
thanks - this will give me a great start to experimenting with patching. Much appreciated
Greg
Greg
if needed you also have a chapter about my first patching in the manual online
here is my attempt to copy your patch nay-seven. I get no sound when the ball is bouncing around, althoug I do get a sound when I play a key on the synths (so audio works). I have no doubt it is something silly I have done, but if yu could help that would be great.
http://www.sensomusic.com/forums/upload ... 0patch.pat
thanks again, gregh
thanks again, gregh
yes, you have use 0..1 values for all faders, but midi note, velocity are 0..127, length are in milliseconds..
here an example I've improved
download
download
thanks nay-seven - works fine now
I shall make a copy and pull it apart to see what the bits do
returning to this - I am struggling to understand he design philosophy - for example what does "delete patch" mean. When I see something like that I think it will mean that if I have a patch selected in a rack and hit delete patch, I will remove that patch from the rack. But nothing happens, so what is 'delete patch' for in that context?
A way to have 2 patch running is to copy this patch and create 2 sub patch in parallel..?
the delete patch button don't work on this version, fixed on next one (soon)
thanks again nay-seven - I am struggling but see the potential and appreciate your quick help
gregh
gregh
quick update - the subpatch thing worked a treat - thanks again
Users browsing this forum: No registered users and 97 guests
