preset manager
i'm about to patch a preset manager,
i actually use a 1024 matrixcombobox with 10 vst
but it begin to be dirty and muddled.
my idea is to make someting like bigtick zen with more than 128 slot
zen webpage
i want to be able to sort preset by synth/instrument/genre.
for the moment i'm only thinking howto.
any idea are welcome.
i may have found a way to do it,
but the resulting listbox is a list of number (0 to x)
i'd like to sort the 1024 listbox and dynamically make a new one.
edit: if only i had a 'commatext to array' and an 'array to commatext'...
zen webpage
i've found an old bSork's script that could do the job,
but i need some quick help from a script guru
this script output x textout
and i'd like to have a concatened commatext of each output.
could someone help me?
Code: Select all
Gets a comma separated list and outputs ARR_SIZE text fields.
The selected list items (or rather their numbers) are stored in an array which is
saved by the Preset Manager and the Conductor.
bSork, March 2009
CONST ARR_SIZE = 4; // Also update the ARR_SIZE constant module if this is changed.
CONST MAX_NUM = 1024; // This is the max number of elements in the list. Increase this
// when needed, or - with a shorter list - reduce the size to save
// some CPU cycles.
VAR pUpd : Tparameter;
VAR pList : Tparameter;
VAR pNumArr : Tparameter;
VAR pNum : Tparameter;
VAR pOut : ARRAY OF Tparameter;
VAR i, j, len, num : INTEGER;
VAR s, c, d, t : STRING;
VAR list : ARRAY OF STRING;
VAR withinQuotes, quote: BOOLEAN;
PROCEDURE init;
BEGIN
pUpd := CreateParam('update', ptButton); SetIsOutPut(pUpd, FALSE);
pList := CreateParam('sep list in', ptTextField); SetIsOutput(pList, FALSE);
pNumArr := CreateParam('selected elements', ptArray); SetIsOutput(pNumArr, FALSE);
pNum := CreateParam('num elements', ptDataField); SetIsInput(pNum, FALSE);
SetMin(pNum, 0); SetMax(pNum, 100); SetFormat(pNum, '%0.f');
SetArrayLength(pOut, ARR_SIZE);
FOR i := 0 TO (ARR_SIZE -1) DO BEGIN
pOut[i] := CreateParam('text out ' + IntToStr(i + 1), ptTextField);
SetIsInput(pOut[i], FALSE);
END;
SetArrayLength(list, MAX_NUM);
END;
// main
BEGIN
IF (GetValue(pUpd) <> 0) THEN BEGIN
withinQuotes := FALSE;
quote := FALSE;
num := 0;
t := '';
s := GetStringValue(pList);
len := Length(s);
//writeln(s);
FOR i := 1 TO len DO BEGIN
c := Copy(s, i, 1);
IF (i < len) THEN BEGIN
d := Copy(s, i + 1, 1);
END
ELSE BEGIN
d := 'TheEndIsNigh!!!!';
END;
IF ((c = '"') AND (d = '"')) THEN BEGIN
quote := TRUE;
t := t + c;
END
ELSE IF ((c = '"') AND quote) THEN BEGIN
quote := FALSE;
END
ELSE IF (c = '"') THEN BEGIN
withinQuotes := NOT (withinQuotes);
END
ELSE BEGIN
IF ((c = ',') AND NOT withinQuotes) THEN BEGIN
list[num] := t;
num := num + 1;
t := '';
END
ELSE BEGIN
t := t + c;
END;
END;
END;
IF (Length(t) > 0) THEN BEGIN
list[num] := t;
num := num + 1;
END;
FOR i := num TO (MAX_NUM - 1) DO BEGIN
list[i] := '';
END;
FOR i := 0 TO (ARR_SIZE - 1) DO BEGIN
j := trunc(GetDataArrayValue(pNumArr, i));
t := list[j];
SetStringValue(pOut[i], t);
END;
SetValue(pUpd, 0);
SetValue(pNum, num);
END;
END.I think I should have these ( 'commatext to array' and an 'array to commatext') in my archive....
But what do you want the script to do exactly? Give me an example of the inputs and outputs, please!
if this script was modified to one commatext ouput instead of multiout text, it would be perfect:
ideally: a listbox input, an array input and a list box output.
for example:
listbox input is:
a,b,c,d,e,f,g,h,i,j,etc
array input is:
0,1,3,6,8
result is:
a,b,d,g,i
with this it will be very easy to add 'tag' to each preset and filter them.
for example:
listbox input is:
array input is:
0,1,3,6,8
result is:
a,b,d,g,i
Hi!
I don't have such a script, but I didn't have enaough time to finish it...
S if you could wait for a couple of hours, I'll finish it, when I'm back home tonight!
for sure,
take your time,
i'm only at the first stage: planning and thinking about the better solution.
take your time,
Hi fléau!
I skipped some other things to finish it fast...
Skript: Select Commatext by Array
I hope, you'll be lucky with it!
And also that it really works...
hi percuson,
it seems to work perfectly,
thank you!
i have tons of things to do until next week, so i will patch it slowly,
will keep you informed as soon as possible.
edit: the 'no selected items' function is great
i don't have to patch the 'no matches' function in case there is no preset corresponding to tags
thank you!
... no problem...
Right now, my idea is to build a Markov chain Midi generator.
I also have to select items out of a ommatext. So I can use it also for myself...
16.5M file, certainly due to the 64 preset manager:
http://www.sensomusic.com/forums/upload ... anager.pat
1st step:
open the patch
open a subpatch/vst slot
2nd step:
open a vst and wire it like that:
3rd step:
first time use of a vst
select your vst slot in the first left listbox
click the 'add' button
click the 'show vst' button
edit your vst
click the 'update' button
add preset of different vst and tags,
now you can sort your preset by tag.
1st step:
open the patch
2nd step:
3rd step:
edit your vst
Users browsing this forum: No registered users and 85 guests
