Hi All,
I'm trying to set the volume level of the MixerOut module via Lemur for iPad (OSC). Lemur outputs values between 0 and 1 however this does not properly control the volume level of the MixerOut object. I gather the Lemur values need to be scaled using some kind of function. Can anyone point me in the direction of how to do this?
Thanks and regards,
Scott
Controlling the volume of the MixerOut module using OSC
there is 3 sub-patches in modules/data/data manipulation that can help you
for example, if the lemur sends 0 to 1 values use the Change scale( in 0..1 ) and set the min and max out of this sub-patch to -90 and 12
Thanks Nay. I'll give this a try.
I tried the Coeff2db module and it seemed to work ok. I did need to adjust my the upper range of the Lemur output from 1 to 3.98. Is there any problem doing it this way?
Regards,
Scott
Regards,
Scott
Regards,
Scott
Scott
no, you're right, it's a good solution too.
As often, there's several solution possible and i didn't know you can change the range on your side
