Launchpad "Virtual" is possible =?
Taysete_DJ
Unread post by Taysete_DJ » 22 Jan 2013, 18:04
Hello all ! im a brand new user in this forum ...:D
you guys are doing an awesome work...
Im using the free version of Usine , i was looking here , because im a musician and im always experimenting with new stuff ...
Im looking for a "Virtual Midi Sequencer"
I have a Touch sceen and i have build succesfully some midi controlers and midi stuff for my projects..
My question is : there's any virtual midi sequencer that i can use as a "Launchpad" in Usine? some Workspace or a Patch?
I have found a lot of different type of sequencing addons, i tested much of them , but none worked as i expected...
Actually im using BLIP 1000 and BLIP 2000 VST , as a Launchpad , and is pretty pretty coool , but the buttons in the 16x16 matrix are so small (blip 2000)
So , thats it ,sorry for my badass english , im spanish xD
Thanks in advance and keep up this awesome work dudes!
Unread post by nay-seven » 22 Jan 2013, 18:42
Hello and welcome
have you tried the add-on named ns sequenaya...? and if yes, what feature are you looking for?
by "free version " you mean the old free one or the actual demo one cause maybe some add-ons don't work with the old free one..
Taysete_DJ
Unread post by Taysete_DJ » 22 Jan 2013, 19:00
nay-seven wrote:Hello and welcome
Hi nay , thanks for the quick reply
yes i have tryed it , but as with most of patches i have a problem to take the midi signal out
i have looked into the the patch editor and most of these patches doesent have the midi output connected , because are connected to a vst i think...
This is exactly what i want :
A 16x16 (or32) matrix buttons , any line of the sequencer with a different note (editable) if possible , a play button
I want to take the midi note output messages to bring them into my Daw (FL studio, or Ableton) , So as logical im using virtual midi cable (Loopmidi)
ns sequenaya , i tried , but maybe im doing something wrong , i cant send midi data
For example the CC sequencer example (in addons) that works and i managed to send midi to my DAW , but i need buttons :P for a proper sequencing
Thank you very much :D
PD: yes im using the last version of Usine
Taysete_DJ
Unread post by Taysete_DJ » 22 Jan 2013, 19:24
OMG i solved
I just loaded another little midi patch and i changed the name of the input to the same as the output in vst
lol ok :D
Got it !
Thanks nay seven !!
Users browsing this forum: No registered users and 93 guests
