Pan subpatches
noise2sine
In modules/audio/panners, you'll find a sub-patch named surround panner 1 2 which can do the job ?
noise2sine
I would expect something more basic like the one for the main track ?
The sampler module can have up to 64 outs, so not easy to add a panner parameter...
noise2sine
i didn't mean on the sampler ! i was talking more about a subpatch with a slider with left and right .
how can make that ?
how can make that ?
the sub patch surround panner 1 2 is exactly that..?, just one fader..?
noise2sine
Hello Nay,
i'm facing a problem with the sample selection now. i can't move the num file fader in order to select a sample in the list ?! it get stuck on 1 ...
Here is the download link, if you have time ...
http://www.sensomusic.com/forums/upload ... 0X%204.pat
yes, here you create a loop : out change so>in change but in change so out.....
add a pass module+has change like this, will solve the problem :
cool !
if you have some jitter you can add a wait 1 bloc module between the has change and the pass inlet to help.
noise2sine
Hello Nay ,
I have another question. In my patch i'm using 4 sampler using the same general output. My wish now is to create buses in order to isolate a sampler in order to route to an fx track. I have created two buses and used a stop event flow buton. it's working but i'm pressing on the stop button, i can hear a loud feedback sound !
What is the best way according to you for reaching this idea ?
Can you give an example of the way you have patch this..? ( maybe replace vst effects by usine patches) ,
noise2sine
Hello Nay,
Here are the patches i wish to use. So my request is to be able to send to an audio bus a selected sampler . which is the best way for doing that ?
http://www.sensomusic.com/forums/upload ... %20aux.wkp
here a way, with a bus selector : Download
here the patch I've built :
but there's also different way to achieve this, for example if you want use a track by effect you can use the Usine aux system and select them with the mixer track output module
Users browsing this forum: Bing [Bot] and 14 guests
