inverse array values
r.erorr
Unread post by r.erorr » 08 Jul 2012, 20:27
hi.
I want to invert manually drawn log scale to exp scale. fore example if array size is 10 then
exp = log
1 = 9
2 = 8
3 = 7
4 = 6
5 = 5
6 = 4
7 = 3
8 = 2
9 = 1
But I have max array size and not only integer values. So I need some system how to do that. any ideas?
Unread post by nay-seven » 09 Jul 2012, 07:26
the swap array module can be a start..?
caco
Unread post by caco » 09 Jul 2012, 09:27
How about (max value in array - value) + min value in array..?
1 = (9-1)+1) = 9
2 = (9-2)+1) = 8
3 = (9-3)+1) = 7
4 = (9-4)+1) = 6
5 = (9-5)+1) = 5
6 = (9-6)+1) = 4
7 = (9-7)+1) = 3
8 = (9-8)+1) = 2
9 = (9-9)+1) = 1
r.erorr
Unread post by r.erorr » 09 Jul 2012, 12:26
sorry... the question is right, but example wrong - yes, this is swap array.
maybe it is possible convert XY values to array? because I got this trayectory on panner module symetric XY mode.
Unread post by nay-seven » 09 Jul 2012, 15:46
mm, not sure to follow here..we talk about array or XY pad..?
about XY , maybe edit layout/inverse Y axis ..?
r.erorr
Unread post by r.erorr » 09 Jul 2012, 17:24
We talk about array, but maybe trajectory on symetric XY can help here? because this is exactly what I need in array.
Unread post by nay-seven » 09 Jul 2012, 18:26
so it's seems that swap + an 1-x module works :
r.erorr
Unread post by r.erorr » 09 Jul 2012, 23:10
Ou, great, thanks!
