Save text panel XY position
r.erorr
Unread post by r.erorr » 16 Jun 2012, 14:15
Hi, I cant save text panels positions in presets. Is there any other alternatives? Also I unchecked "not saved in presets", but it does not make sense. strange... Maybe that is because I have these panels in polyphonic subpatch?
Unread post by nay-seven » 16 Jun 2012, 14:38
This will works if you link faders to the panel X and Panel Y inlets , and set their position with the fader, even in poly mode
or , second solution, if you want set the position with the panel text itself :
r.erorr
Unread post by r.erorr » 16 Jun 2012, 20:42
Hha! thanks, good solution.
