Problem in FL Studio
fnatic99
Unread post by fnatic99 » 03 Jun 2012, 15:32
I got a problem in FL Studio with usine vst. (when using it as a effect)
I cant map any of usine knobs or switches.
I can see in usine that im getting MIDI signal, but for some reason i can only map one control..its very strange.
Its a very simple setup, ch1, cc 1,2,3...
I have tried with "Midi CC Knob" but with no luck.
Every other plugin works great when using MIDI OUT in FL Studio.
I have latest version of usine vst and FL Studio.
Can some one help me?
Thanks!
fnatic99
Unread post by fnatic99 » 03 Jun 2012, 17:43
OK it works with usine pro vst 5.80.006 but not with the latest version, bug?
There is a problem with 5.80.006, i can only put 5-6 usine vst with my setup
then everything is crashing every time in Ableton Live and FL Studio. Im getting message "External exception C0FB007F"
With version 5.80.12 i can load more than 10 usine vst (same setup) with no problems except MIDI OUT in FL Studio.
Unread post by nay-seven » 03 Jun 2012, 21:08
will try to reproduce this with FL demo, what OS do you use..?
fnatic99
Unread post by fnatic99 » 03 Jun 2012, 21:28
thanks!
im using win 7 64 sp1
Users browsing this forum: No registered users and 64 guests
