Auto Scale templates+ New Tutorial
Unread post by nay-seven » 16 Mar 2012, 14:02
Inspiring by a recent post from seamus here are 2 templates i can't add in the default set
but i find them useful , so i share them.
Those 2 templates work for modules like faders, knobs, and some data outlets
Just add this 2 text files in your folder Usine/template ( you can also add a sub-folder)
Then you'll have this 2 menu when you'll create a wire from a fader outlet :
autoscale_to_0_1 ( will automatically set the minimum and maximum value from your fader/knobs and scale them to 0 to 1 )
Scale_from_0_1 (only for 0_1 faders/knobs : will query you about the minimum and maximum out values you need )
note i don't include them cause you have to know when to use them and i don't want to disturb newbies, for example if you have a knob with 20 to 200 values, you can add a scale_from0_1, but of course will not work....so we can say those templates are ,in a way, for advanced users ;)
Download
I've also create a new tutorial to help you to transform/ create your own templates : Template Tutorial
caco
Unread post by caco » 16 Mar 2012, 15:38
Nice examples, thanks for sharing nay :)
r.erorr
Unread post by r.erorr » 17 Mar 2012, 06:31
Hey, Nay... Is it possible to change right click menu[anywhere in patch] with this template method? It would be very cool to see my favorite items only in this list.
Unread post by nay-seven » 17 Mar 2012, 08:35
Yes, this menu is the templates of this folder ;
TemplatesdefaultEmpty Area
just add/delete templates to create your own right click menu.
r.erorr
Unread post by r.erorr » 17 Mar 2012, 09:57
Great... and Thanks...
Unread post by 23fx23 » 17 Mar 2012, 19:59
cool, gonna study this
billv
Unread post by billv » 20 Mar 2012, 11:22
Thanks. Should be usefull.
Users browsing this forum: Google [Bot] and 17 guests
