connecting vst to bidule
allegro
Unread post by allegro » 14 Mar 2012, 17:33
hi - I'm having trouble connecting the vst export to bidule, can someone help me out?
I've made a vst of simple sliders [not sure to use ones from Interface Design or Midi] They are meant to control options from my synths there. I link the parameters within the interface and when I adjust the sliders they effect my synths just fine, however, when I adjust the knobs on the synth, the info does not relay back to the sliders. I will be working with automation in recording, so I really need those to relay back. Do I have to set up MIDI ports for the sliders in and out within Bidule? Any tips would be must appreciated.
Unread post by nay-seven » 14 Mar 2012, 19:01
long time i don't use Bidule but how do you record your automation..?
allegro
Unread post by allegro » 14 Mar 2012, 19:13
midi yoke through ableton, i could potentially use the vst usine there
Unread post by nay-seven » 14 Mar 2012, 19:37
yes, always good to simplify the process...:)
now, not sure the VST /VSTI you want control send back midi too..?
Users browsing this forum: No registered users and 36 guests
