internal error ?
tanabarbier
not realy a patching question, but I get this "Error: Internal" message a lot when trying to save a patch, a track, a workspace, and when it happens then I can't save anything more.
For all the testing I've done it seems to be due to something that have to do with audio buses in my case, but how could I fix or do anything regarding that ?
I know it is very vague, but I really don't get anything !
Anybody getting the same problem ?
thanks in advance !
thanks in advance !
yep, all the time. I get it in a lot more situations than just saving.
I have not been able to pin it down either....
IMHO many of the messages are more like warnings rather than fatal errors, in my experience a lot of errors are related to the action of moving/copying one patch or module from one place to another in the grid, the buses being the more delicate things.
yes, but how do you know which is which? Which is the one that will make it impossible to save your work?
I always saveAs and restart whenever I see one, otherwise I get burned. I also independently saveAs any patches I've been working on.....
tanabarbier
Yes I agree, it happens in all kind of situations, but I'm looking for the one that keep me from saving my work like you said.
I can save my main workspace only if I take the master track off, and then no pb, but otherwise imposible. And then I can put it back when opening and it works fine. A bit strange.
please report issues by mail!
sometimes I have a frozen screen with an frozen mouse, no keyboard (no taskmanager). the only solution I've found is to unplug the power so I do not crashlogs. this bloking come only when I work on large patches, and I connect modules badly, an (infinite) and exponential number of data are created. I think it's the ram or cpu overloading, maybe an ram hardware error.
not when I use usine my computer seems to work fine, it work fine also in usine when I connect my modules correctly.
cpu protect is set to 95%, nb threads 8, usine pro 5.50.521
windows 7 64, core2duo 6gb of ram
PatcherKit at work.
yes, certainly a memory overload
but please report issues by mail!
