Hi, is there possible to get different tempo/speed for different seq-switches? I tried to connect some of counters to "step position" but it does not affect the values.
- is there possible to turn seq cursor run backwards?
two questions about sequencer
here an idea:
CleverConQueso
On your first question, can you set the seq sync to 'loop' and calculate the duration as a fraction of the master tempo? Otherwise, I think you can put the seq in a sub-patch and set a local tempo. Or what happens when you connect a clock beat to 'next step'?
