routing audio
fnatic99
Unread post by fnatic99 » 22 Sep 2011, 00:51
Can someone tell me how to route audio from usine.exe to ableton live specific channel?
Im using win7 64bit.
Thanks.
joffo78
Unread post by joffo78 » 22 Sep 2011, 08:29
why don't you use usine vst version directly in ableton live ?
fnatic99
Unread post by fnatic99 » 22 Sep 2011, 13:38
yeah i know, but i have problems with vst version.
patch is huge takes about 5 gb of ram.
so vst version is crashing inside ableton live.
but its stable inside usine.exe
Unread post by nay-seven » 22 Sep 2011, 13:50
any chance to using hardware routing..?
i have never test myself but there's also the Jack solution..? ( http://jackaudio.org/jack_on_windows )
fnatic99
Unread post by fnatic99 » 22 Sep 2011, 13:56
i dont have any hardware for routing at the moment.
but ill try to find solution with Jack.
Thanks.
gurulogic
Unread post by gurulogic » 24 Sep 2011, 07:28
How can a patch use 5 Gb ram when the limit for a 32 bit application is theoretically 4 Gb? Just wondering :)
fnatic99
Unread post by fnatic99 » 25 Sep 2011, 16:17
good point :)
i have running 2 usine.exe and i have "split" the patch in half for each usine :P
gurulogic
Unread post by gurulogic » 26 Sep 2011, 09:04
hmm, sounds complicated :) I can't guarantee it works as you need it to but you could try Usine VST in the jbridge wrapper. This would let you run two Usine VST's with each VST instance and Live having their own memory uses. You can try the demo to see, and the licence is cheap enough for such a usefull tool. http://jstuff.wordpress.com/jbridge/. Last I checked jbridge would treat each time the Usine Pro VST is loaded as separate instances instead of linked as normal but if this has changed you can also duplicate the Usine VST in your VST folder to run two instances.. so many options, so little time ;)
fnatic99
Unread post by fnatic99 » 27 Sep 2011, 23:14
I have tried fx teleport, virtual cabel, Jack...
I completely forgot about jbridge.
A little bit of experimenting and it turns out that jbridge is exactly what i need :D
Thanks for reminding me what a great tool jbridge is.
Appreciate your ideas!
Cheers!
Users browsing this forum: No registered users and 33 guests
