automatic (timed) fader
antwan
Unread post by antwan » 14 May 2007, 13:54
I might be tired but I've been trying to figure out this rather simple puzzle:
Lets say I have a gain module for volume.
Then I have a trigger button. When I press that button I want the volume to slide from where it currently is down to infinity in a given time.
thanks
antwan
ps. as i'm learning more and more all the time, i really think this program is superb.
Unread post by bsork » 14 May 2007, 14:11
Hi antwan,
I've included something very similar in the next version of the PunchInloops, which I'm afraid I'm not quite finished with yet. I tried several different approaches, but ended up with what I thought was the least "elegant" solution programming-wise (this is a geek speaking, I'm afraid).
I don't have the program here at work and I don't remember too well what I ended up doing so I could describe here and now, but if you want me to mail it to you sometime tonight, I could do that. If you don't want your address here on the forum, mail it to me at bsork@online.no.
antwan
Unread post by antwan » 14 May 2007, 16:32
hi,
thanks a million, i'd appreciate it. i sent you an email.
antwan
bmoussay
Unread post by bmoussay » 15 May 2007, 09:43
Hi Antvan,
To do this you can use either the "data smoothing" module,
or if you need some more complex control, you can "draw" an enveloppe in the "data/lines" module.
You can also check the "enveloppe" modules.
Rgds,
B.
Unread post by bsork » 15 May 2007, 10:31
Hello bmoussay,
my first attempt at doing this used the smoothing module, but I found out that the trouble with using that in this context was resetting the values when for instance I wanted to go from 1 down to 0 when the current value wasn't 1. I ended up using two data/lines modules - one for fade in, and one for fade out - but since my drawing sucks I let them have only two values and patched the output through the data/mapper (curves) module with curve set "log or exp" to get fades that sounded ok. To my ears anyway...
bmoussay
Unread post by bmoussay » 28 May 2007, 22:07
Hey Bsork,
Hadn't noticed your reply.
That's exactly what I've done on one of my sampler patches.
I have a "mute button" connected to some of these "fade in" or "fade out" modules, that allows the sound to enter or fade slowly.
The fade subpatch is like you described: lines module -> mapper curves
By the way combining several line modules we can draw quite complex enveloppes.
Rgds,
B.
antwan
Unread post by antwan » 30 May 2007, 16:27
Hi Bsork,
Didn't have the chance to thank you for your fade patch yet. We were touring. But it worked like a charm. Thanks a million.
I'll try and give a comprehensive report of my experiences from using usine on stage. Generally very pleased. I just need to collect all my thoughts!
antwan
Unread post by bsork » 31 May 2007, 14:00
Hi antwan,
glad to be of help, and looking forward to your report!
Vincent
Unread post by Vincent » 31 May 2007, 17:46
Some testimonials of Usine on stage, with the best and the worse. Since Usine is born to be a stage monster, that could be very interesting for all of us. I'll be glad to read your feedback, Antwan, since I'll start live with Usine in a few short weeks.
Users browsing this forum: No registered users and 125 guests
